10 bolt crossover steering???'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Oct 16, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    10 bolt crossover steering???\'s
    I need to know the best way to setup cross-over steering on a 10 bolt. Does anyone make a kit? Any suggestions would be helpful.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 10 bolt crossover steering???\'s
    search theres tons on it
    everyone and thier sister makes a arm for it.
    ORD
    SKY
    SHAKERBILT
    the list goes on....
    2wd box
    ford pitman arm
    see above names for a drag link too.
    Oh and you need a 1st style dana 44 flat top passenger side knuckle.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I *think* you need a minimum suspension lift, as well...
    Check out this link http://www.offroaddesign.com/Dana44crossover.htm
    I think they explain everything you need. I've got some flat top knuckles if you can't find any local. PM me if needed.
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    If you have a small suspension lift go with the ORD draglink. It has a bend in it to clear your engine crossmember. I only have a 2 1/2" lift and have no issues with it hitting.
  5. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Just did this with a 44, here is what you need...
    1. Both side flat tops. The taper tie rod location is different won't mix and match. have the pass drilled and tapped
    2. early style tie rod, or zero rate as the stock tie rod will hit the spring. There is a guy selling these (new moog) cheap on ebay.
    3. Steering arm, I used a sky mfg. 75.00 with hardware, their customer service rocks.
    4. drag link, I used a sky mfg here too. 84.00 to my door +
    TREs.
    5. drop pitman arm, I used a skyjacker #1104.
    6. #2 reamer 1.5" per foot, You need to ream the pitman arm, once again, the cheapest one I found was a guy on ebay 35.00.
    7. 2wd box
    While you're at it might as well go hydro assist.
    box tap was easy, I think I have 30.00 in fittings and lines and a 59.00 ram.
