10 bolt / Dana 60 lift height question
Discussion in 'The Garage' started by BlitzK5, Oct 26, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Does changing from a 10 bolt to a Dana 60 increase your lifted height in the front? Are the spring perches higher on a Dana 60 or are they the same. My K5 sits higher in the rear right now and I’m just wondering when I install a Dana 60 in the front if it will increase the ride height a bit. I don’t want to waste money on 1" zero rates if I don’t have to.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I believe the D60 will raise the front up 1/2 to 3/4" if I remember right.
    Harley
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Swapping in the Dana 60 will lift the front about 3/4 inch.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Yep, i'll second that the D60 will give about 3/4" lift, at least it did in my blazer.
  5. raggedyman
    raggedyman Newbie
    Jun 19, 2003
    Going from a 10 bolt to the Dana 60. Will raise the frontend 1" . It's the same with the 3/4 ton Dana 44 front axle.
