10 bolt disc conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1BAD88, Mar 21, 2002.
  1. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    Is ther a cheap way to convert a stock 10 bolt to disc brakes using junkyard parts????
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  3. Michael
    1,576
    Sherman, Texas
  4. dyeager535
    26,979
    I don't think those will work. 10 bolts are rectangular bolt pattern, not square.
    Come up with brackets to use 76-78 El Dorado calipers, (or figure out if the front 10 bolt backing plates will work on the rear I think someone said they did) and you are pretty much set. Use front 10 bolt rotors and you should be pretty close. ElDo calipers are pricey, but under about $90/each with core charge.
    I'd do the brackets or test the front backing plate idea, but I have too much other stuff going on though...
