10 - bolt FF Kits
Discussion in 'OffRoad Design' started by Panther, Jan 10, 2001.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hi Steve! I have some questions about your 10-bolt FF kit.
    First, you say it fits 67-87 trucks. Can I assume that also will fit my 90 K5?
    Secondly, I have more of a general axle question. I need to replace (soon) everything in my axles except my ring and pinion gears. Would this kit include everything I need besides the differential itself?
    Thanks for the info!!
    <font color=blue>"You call it clearance, I call it head room." [​IMG]</font color=blue>
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The FF kit replaces all of the outer parts, it does nothing in the diff. Want to buy a built rear? :-)
    You have to have the 3.25" axle bearing. I think '88 up used a larger bearing. That's the determining factor. If that won't work, a good SF alloy shaft would work next best.
    SW-ORD
