10 bolt fill plug
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Apr 1, 2002.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Is there an easy way to get this thing out? Why didn't they just put one in the cover like on the front. Thanks.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    All I ever use is a 3/8 extension and a ratchet. The square end of the extension fits in the square hole perfect.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Yep, that's what I allways use. You may be eble to get out with just a 3/8" ratchet with no extension.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If yours is stripped like mine was, get a bolt and have a muffler shop weld it on to the plug. Mine was probably a 7/16 bolt, the head is 9/16. Now you can use a 9/16 socket to get it off, which is a lot easier.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I was able to get it out with just a 3/8" ratchet. My 10 bolt even looks to be in pretty good shape /forums/images/icons/cool.gif. You can see the wear on the ring gear, but its not much, and there was nothing in the bottom of the housing.
