10 bolt front, 12 bolt rear plus 454. 37" tires or no.
Discussion in 'The Garage' started by Kingston, Aug 27, 2004.
  1. Kingston
    Kingston Registered Member
    Aug 1, 2001
    7
    Alberta, Canada
    10 bolt front, 12 bolt rear plus 454. 37\" tires or no.
    I want 37" tires however I have a 10 bolt front and a 12 bolt rear. I also have a 454 in my 82 K5. I will not be doing crazy 4X4. More for looks. Will I be able to get away with this setup or should I just stick with th 35's even though there so small these days. I plan on going to 4:10 or 4:56 gears. <font color="black"> </font>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 10 bolt front, 12 bolt rear plus 454. 37\" tires or no.
    I would go 3/4 ton and put 4.88 or 5.13 gears in, especially if you intend on running an automatic transmission.
  3. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Like Tim says, "Go 3/4 ton" you will be a lot farther ahead in the long run, plus fewer headaches!
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with a 454 and 1/2 axles your just asking for problems, no matter what size tire you run. the bigger the tire, the more stuff your gonna break.
    like the others said, go with 3/4 ton axles. if all your doing is for looks, all you need is 4.56 gears for the 37s. if you want it to be able to accelerate quite fast, go with 4.88 or lower.
