10 bolt front axle question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IGOR, Aug 6, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Anyone know the torque spec on a 10 bolt front axle for the inner and outer hub nuts? All my books are for older rigs with Dana 44s only - or can I just use the specs for that axle?
    Thanks! /forums/images/graemlins/thumb.gif
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I think the far inner one (closest to the bearing) is torque to 50lbs. then back of 1/4 turn then retorque to 35lbs. The other nut I think is somewhere around 80lbs.
    I could be wrong thou.
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    71
    Humboldt/Pacifica, CA
    Tighten the inner to 50 ft/lbs while rotating the rotor. Back off the adjusting nut and retorque it (35 ft/lbs for auto hubs and 50 for manual hubs). Outer locknut gets tightened to 160 ft/lbs.
  4. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    160 lbs - WOW /forums/images/graemlins/eek.gif
    Okay
  5. rampage
    Mar 20, 2001
    2,259
    71
    That's straight from the GM manual so I'm not going to argue with them /forums/images/graemlins/grin.gif
  6. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Cool - thanks for the info - I believe you then /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
