10 BOLT FRONT AXLE TEARDOWN
Discussion in 'The Garage' started by fwc, Oct 18, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    Went to replace the wheel bearings, how in the heck do you get the bearing "adjusting nut" off? I have the socket for the lock nut, but I can't see how to get the next one out. Tnanks /forums/images/graemlins/thinking.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I usually try a nice screw driver or chisel and drive it around. Shouldn't take more than a little bit and then it should easily go around. I haven't torn a 44/10 down in a bit but I seem to remember it being pretty much the same as the 60.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one you get the first nut off, there is a lock plate that keeps the first one fron furning. grab a curved pick and get behind it and pull it out. then use the nut socket and remove the second nut.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh yeah, I usually use needle nose to get that thing out.
  5. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    There is a nut - lock washer - nut.. did you get the lockwasher out? they are sometime hard to get loose. Should come straight out.
  6. fwc
    Nov 2, 2003
    84
    Northern Virginia
    Does the washer have a bunch of small holes around its circumfrence? If so, I just need to use a punch to knock it around to get it loose? Under that is the adjusting nut? and I use the same socket as the lock nut? Sorry for all the questions, just dont want to have to tear into it again and still not know what to do. Thanks./forums/images/graemlins/waytogo.gif
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes the washer has a bunch of holes on it. you should beable to just pull it out. only had one give me fits. then you use the same socket on the adjustting nut.
  8. fwc
    Nov 2, 2003
    84
    Northern Virginia
    Thanks for all of the input! /forums/images/graemlins/peace.gif
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    DO NOT use a punch to knock it around. there is a notch in the spindle that the washer slides on. pull it straight out.
  10. fwc
    Nov 2, 2003
    84
    Northern Virginia
    /forums/images/graemlins/shocked.gif Thanks for the tip, wouldnt want to destroy the damn thing.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have small fingers so I just reach in and pull it out.
