10-Bolt front-end problem..HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, May 21, 2003.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    After a long road trip towing a boat I'm finally living in Colorado. On the road I noticed that my left front hub was flinging grease. Today I pulled it apart to look around, pulled the bearings, everything looked fine. When I lock the left front hub and drive in 4-wheel, something in the wheel squeeks with every rotation. When parked with the hub locked, just turning the wheel does the same thing. It doesn't do it with the hubs in 'free.'
    Now I didn't pull the spindle but I'm wondering if that bearing could be toast. Is there a way to check the bearing without ripping it all apart again?
    From what I've read in previous posts it sounds like a tough job replacing those suckers.
    TIA,
    smack
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Sounds like it may be that bearing inside the spindle bcos the the only time the axle moves is when the hub is locked in. Never replaced one before. Not even sure how you would tackle that.
