10 bolt front gears
Discussion in 'The Garage' started by blazd88, Sep 29, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    ok i have to find some gears for my front diff now that i have 4.10 in the rear. what should i look for(and where)?i cant ramamber if i need reverse cut or not(been away from wheeling to long damn racecars). anyhow used would be ok since its going up front and it wouldnt be engaged all the time right? thanx for the help cause i feel retarded. /forums/images/graemlins/doah.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    iirc the front gears on a 10 are identical as the rear. not sure where to look though.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There's no such thing as a reverse cut 10 bolt.
  4. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    like i said i felt retarded it was a long night last night and im still feeling the effects. /forums/images/graemlins/doah.gif
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well there is no such thing as a reverse cut GM Corporate 10.. But there are reverse cut Dana 60's(have 10 bolts ont he diff cover) and the D44 which have 10 bolts on the diff cover AND on the ring gear.. /forums/images/graemlins/wink.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif Sorry, just being a smartass! /forums/images/graemlins/thumb.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm real clear on how many bolts go into the cover on my Dana 60.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Dang, I was just jokin with you!!! Dont get'cher panties in a wad! /forums/images/graemlins/wink.gif
  8. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    I got a set of yukon 4.10s for the 8.5 and a 30 spline auburn posi i am selling. I removed them after 1 year of use in the front differential of my blazer.(which probably translates in to less than 500 miles) Only took them out becuase i went to 5.13s and a powertrax locker. /forums/images/graemlins/peace.gifpm me if intested
  9. hfactor
    hfactor Registered Member
    Aug 29, 2004
    11
    Just a hint to the original poster the Dana 44 & 60 diffs have about 4 straight inches of up & down flats on each side of the covers.
  10. rmadrigal10
    rmadrigal10 Newbie
    Jan 15, 2006
    corpus christi tx.
    NEED HELP are front gears different than rearend gears
    want to learn more about gearing. i have an 83 k-5 blazer, i have been looking for 4.10 gears for the front 10 bolt. i have been looking for used gears. i hardly use 4 wheel. i have came across people selling 4.10 rearend gears. can i use the gears. does it matter. help me out guys, i need the the CK5 smarts....:bow:
