10 Bolt Front Loaded Price Dropped
Discussion in 'Suspension | Axle' started by MUNSONSRODSHOP, Nov 11, 2006.
  1. MUNSONSRODSHOP
    MUNSONSRODSHOP Registered Member
    Nov 11, 2006
    5
    Vernon, Texas
    This is the front out of my comp rig. 10 bolt front, ARB air locker, 4:56 yukon gears, Yukon cromos inner and outer, Yukon super joints, drive flanges,44 flat top knuckles, high steer arms, cross link, PSC hydraulic ram, all new ball joints, bearings seals, BTF diff cover/armor, also have a second brand new set of yukon cromo inner and outer shafts with yukon superjoints, 1350 u-bolt yoke, ball joints ect.......... $2500 This is a turn key unit with NO problems has everthing from rotors and calipers to you name it. To be sold as a unit will not separate. It has leaf spring mounts on it and dual shock mounts.
    If you have any questions, please contact Mark Munson 940-357-0223 Vernon, TX
    NEW FRONT AXEL ON ITS WAY
    MUST SELL $2000
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Good luck selling a 10B on here for $2K
    -Harrison
  3. MUNSONSRODSHOP
    Nov 11, 2006
    5
    Vernon, Texas
    You can't buy the parts and build a turn key front for that.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    If you decide to part it out, I am interested in the X over steering parts. Let me know......
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its a well built axle, however most people would rather buy a d60 and lock it for less than $2k and would be just as strong with stock axle shafts. try pirate4x4.com
  6. MUNSONSRODSHOP
    Nov 11, 2006
    5
    Vernon, Texas
    thanks and your probably right. I just ordered a turn key rockcrusher hi pin 60 to replace this one. Thought there may be someone with a k5 that would want to upgrade and be able to bolt it right in with almost no changes.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    No but you can build a better axle than that for the same money. Your gonna be better off parting out on here. If you go to some of the Jeep sites though you may have a shot?
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If ya'll don't want to buy his axle, fine. No need to hi-jack his post just to tell him how worthless it is.
