10 bolt front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by steve85fla, May 6, 2001.
  1. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I am in the middle of regearing the front, also putting a mini-spool in there too. I am green to these gear swaps.....anyway, i pressed the new pinion race on and went to assemble. I don't know if my compressor is up to it, but it would not tighten all the way (1/64 play, no preload. Is it common to have a shim under the pinion bearing race? Thanks for any help, great place here!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Are you trying to crush the crush sleeve? if so, we had problems with this also. A trick is to take the crush sleeve and put it in a press and jus slightly start the crush and then install it. We have a pretty big cmpressor here and we couldn't get the sleeve to crush and were told to use that trick.
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, I have that problem too. I have had to take the crush sleeve and put it in a press to get the sleeve some slack. After spending some time with a big impact gun and the sleeve not budging, it was press time. That did the trick. Just becareful not to crush too much. Just enough to get it "broken in".
