10 bolt gear set question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, May 10, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    A while back I bought a diesel burban for a daily driver... one of the upsides to it was newly rebuilt front and rearends. Shortly after I found out the morons put two different ratios in. My luck. Anyways, I have a ring and pinon from the front end of a 10 bolt with the correct ratio. Will this ring and pinion work in the rear of my burban? It is a ten bolt I am just not sure if there is a such thing as reverse cut on 10 bolt gears and that sort of stuff. Anyone have any ideas?
    Thanx
    You call that dirty!?
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I never heard about different ones but I am not sure .
    - SlyDog [​IMG]
  3. mpascino
    Jan 1, 2001
    557
    Connecticut
    I know for a fact that some of the later dana 44 axles had a reverse cut on the front ends to make them wear better and be strong in the forward direction, just don't know about the corporate axles.....
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yes they will work. My reading comp is a little poor. But if you have the gears from a 10 bolt and want to put them in another 10 bolt they will work as long as they have the same carrier size.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
