10 bolt gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazd88, Apr 9, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    what is the largest gear that can be put in a 10 bolt?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, 5.13's is pretty far up there, but I think Summit has something for the 10 bolt around 5.50 /forums/images/graemlins/dunno.gif /forums/images/graemlins/yikes.gif
    I'd be weary of putting 5.13's in a 10 bolt because that most likely means two things. 1) you're running a rather large tire and your 10 bolt's not going to like that. 2) the torque multiplication of 5.13's is going to love eating axleshafts.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The other problem with 5.13's in a 10 bolt is the pinion gear is getting real small and you become in danger of snapping your pinion under heavy torque or tearing off teeth because you don't have very many on the pinion with 5.13's.
    Harley
  4. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    i just want to make sure i can fit 4.10s on the stock carrier. just a fix until i can afford a corp 14 and dana 60
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The carrier brake for the 10 bolt is 2.73 I believe.
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You'll need a new carrier. I currently run 3.08's and I am trying to switch to 3.73's. 3.73's are the limit on the stock 10b carrier. If I am wrong, will somebody please correct me?
  7. xflatrater
    xflatrater Registered Member
    Nov 28, 2003
    65
    Shamong NJ
    I have 4:10's on the stock carrier, and no breakage
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your wrong from what I have been told. 10 bolts have the carrier break really low. 2.73 or 2.56. If you have 3.08s it should be the same carrier all the way up to 5.13.
    I am running 4.56's and I am pretty sure it is the stock carrier (bought the axle built already). When I was going to build my old 10 bolt I was going to go from 3.73's to 4.56's and I was told I wouldn't need a new carrier.
    For the D44 you would I believe. I know the carrier break for the 14bff is 4.10 and I believe that 4.10 is also the D60 break.
    Harley
  9. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I went from 3.73 to 4.56 in my stock 10 bolt (front) and they did not have to replace the carrier. They did for the rear though.
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Was your rear axle a govlock axle though? Did you replace the govlock with anything? If you went to a none full carrier traction device you would have to have a new carrier. In the rear you could install a detroit or other full carrier traction device and have that be the carrier.
    Harley
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Cool! Thanks for setting me straight! I learn something new everyday! /forums/images/graemlins/thumb.gif
    Please disregard my previous post as I wuz talking out my arse again! /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif
