10 Bolt Gears
Discussion in 'The Garage' started by njonl, Aug 14, 2006.
  1. njonl
    njonl 1/2 ton status
    Jun 30, 2003
    128
    Northern CA
    I have a buddy selling a set of 10 bolt 4.10 gears. I need them for the front. Is there a difference in front and rear 10 bolt gears ? Thanks!
    - Nick
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If both 10 bolts are of the 8.5" variety (chevy trucks only used 8.5" ring gears) so yes they should work. 10 bolt gears are the same front and rear.
    The only possible problem is if you have 2.56 gears in your truck. I have never seen anything lower then 2.73's. 2.73 is the carrier break so if you have any gears 2.73 or higher you are fine.
    Harley
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    If its both from the same truck, get the front. Less mileage.:D
