10 bolt gov-lock, how to remove axle?
Discussion in 'The Garage' started by divorced, Mar 5, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I will be going to my friends house shortly to help him remove an axle shaft from a 10 bolt rear with a gov-lock. I have never removed one from a gov-lock, only an open diff with the c-clips. He says he can't figure out how to remove them, he says some type of "I" shaped metal block is in the way. How do they come out? If ya'll tell me the trick he will think I'm real cool... :D
  2. hawk368
    hawk368 Registered Member
    Jul 29, 2004
    50
    White Salmon Wa.
    :doah: :thinking: I just did mine about a year ago. Now you had me thinking, And now my head hurts.:frown1: :confused: I'm to tired to think, but I remember it was easy after I pulled the cross pin. Took me about 5 min. to figure out.:thumb: Good luck.
    If I remember anything else in the morning I'll post. Not that it makes any diff, but mine was a 12bt.
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    you pull the pinion shaft just like you would with an open diff...... you push the axle in, and pull the c clip..... i believe there should be just barely enough room.... that I shaped thing is shapped like an i for a reason.... to give you room to pull the c cip.
    my govlock had to be cut out... haha.... it was cracked in half, and it tore the gears up real bad, and they were froze up..... i couldnt turn it to pull the shaft..... so i just cut it apart... it was trash anyways.
  4. divorced
    Jul 20, 2004
    5,115
    Thanks, we'll give it a try. We have never had to take one apart before, they were always destoyed so we just replaced the whole rear end.
