10 bolt help?
Discussion in 'The Garage' started by Mr. Jimmy, Nov 24, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I have a 28 spline 10 bolt with 4.56 gears and an Auburn LSD. Can I use this carrier and axles in a 30 spline housing and install 3.42 gears on the carrier that previously had 4.56's on it?
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    every thing should be pretty much the same. i know that the 30 spline axles are bigger in diameter where they go into the carrier. so check the outter bearing and seal to see if it is still the same size. and yes the carried should take a set of 3.42's. good luck
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
