10 bolt inner axle seals.. where to buy?
Discussion in 'The Garage' started by scrappy88, Jun 28, 2005.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I'm tearing into my front 10 bolt and replacing the ball joints, wheel bearings, etc. Since it's all apart this far I'd like to replace the inner axle seals and the spindle seals (the ones on the axle shaft). I know what needs to be done but I just need to locate the parts. I have been searching ck5 and the parts stores websites but can't find where to buy the seals. Autozone is of no help so far. I really need these quickly, as I need to have it put back together within a few days. Thanks!!
    Steve
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I know for a fact we stock like 6 of them at the Napa where I work. sent you a PM
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The one in by the carrier is usually called "inner hub seal" and the large one that goes on the bearing hub that seals on the spindle is called the "outer hub seal". The inner one costs like $8/each and the outer one costs like $4.50/each.
    The seal that goes between the axleshaft and the spindle is expensive (and there is also the "slinger" or "butterfly" seal). You can get this as a kit for $3-4. Federal Mogul's part number is SBK1. I can get Spicer's kit later (even cheaper).
  4. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    Ok got the part numbers from Chris
    Napa numbers
    inner axle seal: 13165
    spindle kit (including the bearing and seals): BK1
    Thanks guys!
