10 bolt inner bearing shot, rotor will not come off, what to do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Sep 5, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Yep, the inner bearing is toast. I cannot get the rotor off. I tried pounding, prying , both at the same time, and wd 40. What can I do to get it off?
    I am on a tight budget, so an axle swap is out of the question..
    Chris
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I had the outside bearing freeze on me. Had a guy at work cut it out with torches. Had to replace the spindle, hub and both bearings. But sence it is on the inside, i dunno if torches will reach back there.
  3. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Yeah, I don't think a torch will help in my situation. There is no way to remove the entire spindle with rotor and all attached is there?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. I'd torch the whole hub and rotor off, then unbolt the spindle.
  5. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I don't want to sound like I'm doubting you, but I would think that you should be able to get the rotor off since it is the inner bearing. Maybe try something like a heavy weight and a piece of chain fastened to the lugs and give it a big jerk. Of course, everything might be junk anyway, but since you are on a tight budget, it might be nice to see if anything was salvageable.
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Does the hub spin at all or is it welded to the spindle?
    Something should let go, the seal may be holding it in.
    I have had to rig up a puller to get hubs off.
  7. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Are you supposed to take the brake caliper off before removing the rotor?
    J/K
    Th rotor does move, I can actually pull it out about 2 inches before it won't move any further. All locknuts, snap rings an other locking devices have been removed. Everytime I hit it with the hammer a ton of metal powder falls to the garage floor.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it moves it should come off. Just keep beating it or something. I thought it locked up and welded itself to the spindle.
  9. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    The only thing keeping the rotor on at this point would be the seal. It'll be a bitch. Try putting a 2 arm gear puller on and center it on the axle shaft and pull on the hub. I bet just a couple turns after you get it snug will release it. good luck. /forums/images/graemlins/thumb.gif
