10 bolt inner seal
Discussion in 'The Garage' started by shaun, Apr 29, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    So I am rebuilding the 10 bolt to match my recently installed 14bFF. The question I have is is there a way to replace the inner seal without pulling the ring and pinion? If not how hard is it to remove and replace the ring and pinion on a 10 bolt? Or do I even need to replace this inner seal? How do I know if it is bad? I know I should replace it but how difficult is it? /forums/images/graemlins/thinking.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    Olathe, Kansas
    You have to take out the carrier it comes out that way. You don't need to take out the pinion though. They are not that easy to replace. You need to pull everything from the knuckle out off both sides of the axle and remove the carrier. Does the end of your axle tube leak gear oil when parked off camber if not then yours are still good. If you do replace them a piece of pipe the same diameter of the seal and a little longer than the long side axle tube with a hammer will push them out. To install the new ones I used a socket that fit over the seal and a rubber mallet to tap them back in worked great for the little while the d44 was in the truck.
