10 bolt knuckle pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, Jun 8, 2003.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    anyone have a blow up schematic pic of knuckle and ball joints?
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    What is it you're trying to accomplish? You replacing ball joints?
  3. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Is there any adjustment in ball joints?
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    officially "I dunno" but the other day I noticed one of the top ones was loose so I pulled the cotter pin, got out the biggest pipe wrench I could find and I went to town. It's not loose anymore /forums/images/graemlins/crazy.gif All I can do is replace it if I screwed up. Just didn't feel like it right then and there. Concrete in Tucson in the summer is not a happy place.........
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sort of.... you can turn the pre-load adjuster - its a threaded sleeve that sits in the taper for the top balljoint. Most often its rusty and seized so you need to take the knuckle off to work it loose with penetrating oil. and heat. You need a funky little 4-pronged socket for it as well. I know Snap-on makes the tool.
    You're not actually tightening the balljoint but rather changing the space between them slightly to take up the slack. It works for while, but you will need new balljoint eventually.
  6. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Funny, I didn't hear about this little 'problem' yet! Trying to hide it from us?
    /forums/images/graemlins/grin.gif
    It's Karma for what you did to the poor guy at discount tire
