10 bolt life
Discussion in 'The Garage' started by sprocket11c, Mar 4, 2006.
  1. sprocket11c
    sprocket11c Newbie
    Feb 24, 2006
    wa
    Hey ya'll im sure this is a common question but ive yet to see the response im looking for..Ive got an 87 k5 thats gutted and rhino lined inside and out...ive got a 8 inch lift with 33 inch mickey thompsons but it looks rather stupid with all that room and no meat....how long will the stock ten bolts last with say a 37 inch tire just driving on the street? Im getting deployed back to iraq so i want to save the money for some killer axles when i get back..ive also got an auto tranny and stock gears..thanks
  2. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    If all you are doing is driving it on the street, 10 bolts will probably be fine
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    If you have stock gearing and an auto, you really need to invest in a tranny cooler because you will burn out the tranny very fast without one.
  4. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    what about a 12 bolt with stock gearing and 4 inch lift and 35's???????? anyone!??
  5. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    All will work just fine. Remember its how you use it. If you plan on really palying hard or like me you can't keep your foot out of it you'll want to upgrade. 4.56 or better in the 12b and just get rid of at least that rear 10. good luck guys, remember if it ain't broken U ain't havin fun....! or so they say.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just don't use overdrive unless you are running on the highway at above 55 mph. Otherwise the tranny may not lockup in OD which will cause heat to build up and heat is what causes tranny's (especially a 700R4) to die quickly.
    Harley
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    in my stock 77 k-10 3.07 rig with 33" tires and th350 it has one of those aluminum tube fin tranny fluid coolers mounted in front of the radiator and the tranny lines run through it, but also the lines are on the radiator and running down there too, unless they arent connected to the trans or anything and are just cut off
    would just running the tans fluid through the aluminum cooler be ok ?
    or should i modify it ?
    thanks
