10 bolt locker suggestion
Discussion in 'The Garage' started by 85 Jimmy, Jan 21, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i've got 10 bolt's front and rear in my 85 Jimmy. Today i got in a mud hole and got my buddy to look at the wheels and most of the time only one in the front spins and in the rear if i'm stuck only one spins, but if i goose it while i'm already going both will spin.
    i plan on keeping the 10 bolts till they blow up or untill i get a killer deal on a 14 bolt and dana 60, so what lockers would ya'll suggest for the 10 bolt? i was thinking "lock right" but ya'll probably know more about this than i do.
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You'll probably want to frame your Q with what kind of $$ are you willing dump. You're about to get a lot of would be experts, and good advice; should be fun to watch. '85 10Bs Sub with Lockrite in front, PowerTrax in rear, I love it.
  3. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Whatever you do, don't get 10-bolt gov-locks if you like to mash the loud pedal a lot, unless you like having stuff like this happen:
    Gov-lock Ka-Boom :D
  4. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i don't want to spend tons of money on something that will end up being a waste, but i'm willing to get some decent stuff.
    i don't know if i mentioned it but i will mainly be doing muddin, but this is also my d/d and if it gives up on me then i have my 66 mustang
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    If you plan on getting a 60&14 then dont waste your $ on something that you plan on getting rid of. Just save up and get what you really want.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    you ought to be able to get a 14FF for less than the price of most lockers
  7. LostChild
    LostChild Registered Member
    Mar 28, 2006
    60
    PoeDunk Utah
    Not sure how old this post is Found it through a forum search, Because I was thinking of doing this same thing, So my ? is what would be the brand of choice for a 10 bolt locker, and who would be the best supplier/web site to get it from.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Ya know, just putting a lockrite in front ($200) may be the trick solution. Its probably the least $$ for instant functionality, before upgrading to bigger axles. Try that, first install the lockrite in front, wheel it and take it from there.
    Oh Shnap, I'll bet I don't even need the rear locker.
    Bought mine (Richmond fr & rr) at Randy's R&P.
  9. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I ran a locked rear 10-bolt with 4:10 gears and 33s for over 2 years and only broke one axle shaft. I ran the Powertrax no-slip (glorified lock-right) and when I swapped in a 14 bolt SF rear I put the 10 bolt locker from the rear up front. Both front and rear are locked now and so far so good:D
  10. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Stick shift?
  11. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    Auto; 700R4
    I swaped in the 4:10 gears. I probably wouldn't have broken the shaft with the stock 3.42's.
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'm curious, 700 first gear+4:10 starts to impact like a clutch? What T-case is that (4L)?
  13. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    cheap+crappy axles=welded
  14. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    No impact. Torque overload as near as I can tell; 4L w/o front hubs locked:D
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah, thats what I was wondering, what T-case/4L ratio?
  16. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    NP208, 2.61 low range I believe.
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah, you must have reached the outer limits; 700, 1stx208, 4Lx4:10/15.5R with all the weight on the rear, POP.
  18. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I've heard good things about the Aussie lockers..
  19. goldwing2000
    goldwing2000 Guest
    I could be mistaken but I don't think they make them for 10-bolts. Last I checked, it was all for Dana stuff.
    edit: yep. just for the Dana 44 up to 1980
    http://www.offroadlockers.com/make.php/TMf3a993/f3f8/03/.html
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    yet (?)
