10 bolt on 36s?
Discussion in 'The Garage' started by jk3078, Dec 28, 2005.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    How many of you runnin a welded 10b rear with 36'' or bigger tires? Is this asking for trouble? I'm getting gears for my sub-buggy( 4.56or4.88) and I'm looking at all my options. I've got a 14bsf 8 lug I could put in but a 10b is lighter and has more clearence.The buggy is fairly light, 3700# or so, but I do wheel pretty hard some times.The axle is a 28 spline, could I use a 30 spline front carrier with 30 spline axles from a newer rearend? How much Would this boost the strengh? JUst tryin to look at every angle, thanks for any info.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i think if you're looking to stick to half ton go with a 12bolt rear... a few guys down in phoenix have wheeled 35s on 12 bolts for years... and they wheel really hard
  3. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    you should be ok. depends on the driver
    there's a guy here who had a truggy on 40s with 1/2 tons. he had it around 2600 pounds though...:D
  4. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    doo luck with your 1/2 tons holding up to ANYTHING bigger than a 35
    LUKE
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the 10 bolt i had in my 91 K1500 broke with bald 31s on it. i wouldnt even think of trying anything bigger.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ran 35's with open 10b's with 3.73s and never had any problem with them. as long as they dont have any kind of traction device you will probably be ok, jus lay off the gas pedal
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My buddy has a 10 bolt front welded with 36" IROKS and we rock crawl. He has 3 runs so far without breakage, but I suspect it will happen sometime soon. He does have a rear 12 bolt with Superior axle shaft which are pretty darned cheap. I would go that route with a rear axle if you really want the ground clearance. I myslef have the"Set it and Forget it" 14ff :)
  8. mudboy
    mudboy Registered Member
    Dec 27, 2005
    7
    Atco, NJ
    :dunno: on my old 3/4 ton pick up, which had a 10 bolt in the front, I blew both hubs first then put a good set of warns on, then I snapped a front drivers side outer and the following day i snapped the front passenger side outer. Oh yeah this was with 33" bald terrains in the mud. Now I do remind you, I do have an extremely heavy right foot but then again I was still dissapointed with the stock 10 bolt axles.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i guess people have different experiences. i have a heavy foot and i never had problems with 35s
  10. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    I'm running 35x12.50 M/T's on some 15x10 alloy rims with my 4runner. and a D44 upfront and a Toy 8 V6 in the rear. No probelms and I beat it hard offroad. I think weight has a big factor in breakage. in the toyota world we say 37" max on a Toyota axles, or D44's. we weigh about 4K and have 150HP MAX! lol.
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    toy axles are surprisingly very strong eventho they have a small ring gear.
  12. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Well I'm running a set of bald 35'' ssr's right now but its only went through 5 trail runs and the 2 day fall mud bog and no problems yet,stock 3.43(sucks)gears and welded front and rear I also do hammer down alot.Those Iroks i'm gittin are going to hook up way better though.Maybe the 14bsf is the way to go. Any more .02?
  13. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I gaurantee that it will work
    Till it breaks:D .
    Ira
  14. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    open or conventional locker no problem... welded ... no way. Plenty of guys on here running 36x12.50 tsls on 10bs and lockers with no problems.
    If your the kind of guy that can't wheel without denting the floor board under the pedal then get some 1 tons. If not then they will work fine with a smart driver. Welded is asking for it on 10bs tho.
  15. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    Most of what I've seen break on 10 bolts is the spider gears so if you weld them all together into one big lump maybe they will survive. Eliminate as much excess weight as you can and keep out of the go pedal.
  16. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Of the 3 10 bolts and 1 12 bolt I destroyed all had a broken carrier/spider gears, If I were to run 1/2 ton stuff again I would do it with a full replacement diff (detriot locker or full spool) and use a diff cover that allowed me to keep tension on the bearing caps to keep them from deflecting, but then again 14 bolts are cheap and I can drag them over whatever I want.
    I'm sure this has been brought up but why don't the guys who want 1/2 ton stuff and strength run 9" rears?
  17. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Low pinion+five lug axles+Ferd part=NO!!!
    As far as weight theres nothing left out back on this truggy as I cut all the body off behind the front seat. What about the newer 10b 30 spline diffs anyone know if these are much stronger than the 28s. I see several people have recomended 12bs but my main prob. with these is the pinion bearings going out and chewing up the ring gear.any .02 on this?
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what about 10/12b full floater conversion if you wanna stay 1/2ton?
  19. resurrected_jimmy
    May 23, 2005
    2,241
    I can't remember if 10 bolts are high pinion or not but 9" can be had either way and there are several manufaturers that will drill the flange anyway you want and you could pick one up from currie that has absolutely nothing to do with ford, but then again henry made the V8 possible so try not to hold that against him
  20. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I heard they quit makeing those floater conversions, anyway probly outside of my budget any way,its hard doin much when you got a family. Thats why my junk all looks like rolling piles of rusted scrap metal!:haha:
