10 Bolt pinion bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Junkie, Feb 10, 2001.
  1. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    Does anyone know what the torque spec is for the rear pinion bolt on a 10 bolt axle? Thanks in advanced.
    <A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Which bolt are you refering to? The cover bolts?
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I think he is talking about the big nut that holds the yoke on....
    Murphy's Laws on Life :
    "Never step in anything soft."
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, if that is the case we still need some more info. If he is replacing the seal or yoke or something like that, then he needs to get a standard 1/2 drive ratchet with an 1 1/4 socket and tighten it as tight as he can get it. The crush sleeve is still hard enough that he wont be able to over tighten it with just a standard length ratchet, " NOT USING A BREAKER BAR FOR LEVERAGE", but if he is dead set on the specs he will need to refer to a haynes or chiltons manual, I cant recall off the top of my head what the specs are.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    What is a rear pinion bolt ?
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    LOL!!! thats what we've been trying to figure out.
  7. Rowdysr
    Rowdysr Registered Member
    Nov 18, 2000
    20
    Whidbey Island, WA.
    250 Foot Pounds
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, but that 250 ft/lbs. is for installing a new pinion isn't it? Thats the amount it takes to start crushing the crush sleeve. It all depends on what it is he is doing. Besides, we need to make sure we know what exactly he is talking about. He needs to be more specific as to what he is talking about and what he is doing.
