10 bolt pinon nut
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Nov 20, 2000.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Does any of yall know what size socket the pinon nut requires for removall? TIA
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    A very large one!!! :)
    I dont know off the top of my head, but I can find out tonight!!!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Yes, I know this part!!!!
    blazen91
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I know my bro will know off the top of his head, so i will ask him as soon as I get home and then I will post the size as soon as I find out..
    Mike [​IMG]
  5. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks Dude, you're the man!!
    blazen91
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm not sure what size it takes, but let me tell you that I needed 1 5/16" thin wall socket to remove the output yoke on my NP205. Every parts store in town had the socket, but not a thinw all. Ended up having to grind the ears off the yoke to get a thick-wall (like an impact socket) on. That was OK since I was upgrading to a 1350 yoke and my 1310 yoke was slightly hashed from a driveshaft failure.
    You might have the same problem with the socket being too big around to fit in the yoke, esp. if it's a 1/2ton (1310) yoke on your 10-bolt. I wish you luck in advance, because I never could find a thin-wall in 1 5/16"...
    -- Mike
  7. edeslaur
    edeslaur Registered Member
    Oct 31, 2000
    69
    Portland, Oregon
    Dude, grind a socket if that's the case. Sears may even take it back if you break it.
    Eric D
    88 K30
  8. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I bought a Sears socket, but I don;t think they'd take it back if I ground off the outside.
    Like I said, I didn;t need the hashed 1310 yoke anyway - would have needed a new 1310 yoke if I wasn;t upgrading.
    Not even the Snap-On truck had one.
    -- Mike
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I believe the pinion nut is 1 1/8"... I may be wrong, it has been a few months since we did this.
    HTH!!!!
    Mike [​IMG]
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I believe it's 1-1/8, but measure flat to flat, and you'll know for sure.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    There we go, thinking and posting the same thing at the same time......[​IMG]
  12. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks all!
    blazen91
  13. edeslaur
    Oct 31, 2000
    69
    Portland, Oregon
    Take back as a return (after grinding)? Definitely not
    Take back after you break it? Sometimes. Depends on how cool the sales guy is.
    Eric D
    88 K30
