10 bolt posi front?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FastEddy, Mar 6, 2001.
  1. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    I heard that the posi carrier out of the big 10 bolt diff in 70's cars/80's pickups will bolt in to the front diff...is this correct? I have a 79 z-28 in the back yard with a 3:73 geared posi diff, can I use this carrier with the gears in my front diff (87 suburban) thanks in advance...ED
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    BIG?? Do you mean 8.5? as in big If it is an 8.5 10 bolt it should hop right in there. But you will need to have it set back up correctly. As the axles housings are line bored and each one is different.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
