10 bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, Dec 17, 2001.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    Yet another question
    I was talking to a guy on the phone about buying a 10 bolt front,4:10 gears from his 1983 Jimmy.
    The problem is ,,,he says it has 35 spline axles????? is this possible,, If so will the gears fit on my 10 bolt 28 spline in my 1988 Blazer???( I only want to salvage the gears.)
    Ken
    <a target="_blank" href=http://www.blazinobsession.com/>http://www.blazinobsession.com/</a>
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Tell him to get someone who can count to check the splines. I think the only axle to have that many splines is a D70!
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  3. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Yes the gear set will fit even if his is a 30 spline 10 bolt. 10 bolts were never came in a 35 spline variety, at least not in a truck. If his 10 bolt is stock it should be 28 just like yours.
    Great website by the way. If your ever in Richmond look for my Jimmy, its prolly the only one in town.[​IMG]
    James
    jimmy79@shaw.ca
