10 bolt re-gearing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AK-5GUY, Feb 18, 2003.
  1. AK-5GUY
    AK-5GUY Registered Member
    Apr 24, 2002
    89
    Greensboro, North Carolina
    I want to re-gear my front 10 bolt from 3.42 to 4.56. I may do it myself, but if it looks to hard I will probably let a shop do it. Does anyone know what a shop might charge to put 4.56 gears into a front 10 bolt? Also, if anyone on here has a front 10 bolt for sale with 4.56's for around $150, let me know. Thanks.
    Harrison
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    You can probably count on about $50-80/hr. I dont know how long it would take to do it, but I'm guessing probably atleast about 2 hrs. The best thing would be to call around and find out, only the shop that's gonna do it can tell you how much they will charge.
  3. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i called around and i got about $1000 for all parts and labor, dunno how hard it would be though..
  4. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    It may be cheaper for you to buy the parts and then find someone to put the gears in /forums/images/graemlins/truck.gif
  5. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    4 wheel parts down here in orlando wants $575 for gears install kit and labor.thats about right in the ballpark.
  6. AK-5GUY
    Apr 24, 2002
    89
    Have any of yall ever done this yourselves? How hard is it to do?
    Harrison
  7. 90K5Blazer
    90K5Blazer Registered Member
    Jun 10, 2002
    48
    Dayton, Ohio
    Its not difficult, just very, very time consuming. Not to mention it is very tedious work. If you have access to alot of measuring tools, (i.e., calipers, dial indicators etc.) then give it a shot. If you don't have alot of free time then let someone else do it. /forums/images/graemlins/ears.gif
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I re-geared my front 10 bolt in about 8 hours. We took a lot of breaks...anyway, the hardest part is crushing the crush sleeve. Get the longest breaker bar you can and jump on it and it'll slowly turn. A shop press wouldn't hurt and a bearing puller would be nice too.
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You are joking about finding a 10-bolt front with 4.56s for $150, right?!? The gears alone with an install kit will run that. Gears alone run around $100. A COMPLETE install kit should run another $75-85. You can do it yourself, but will need various specialty tools and a lot of patience. Gears aren't that hard, but do require precision. If not, they won't last long and all your work becomes for not. Then again, doing it yourself teaches you a lot about what is going on inside the axle making it easier to troubleshoot a problem later when you may be 20 miles form the nearest pavement!
    Going rate around here for gear install alone (no parts) is around $350 for a front axle and $250-300 for the rear. You are planning to re-gear both, aren't you?
