10 bolt REAR axle- When did GM change from 28 to 30 splines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thebigdaddyof2, Nov 7, 2002.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Does anyone know for a fact what year GM changed the REAR 10 bolts to 30 spline. I know it was between 1986 and 1990. It seems when they did this, they moved the weak spot from the axleshaft to the carrier. The carriers are failing...the area of the carrier where the bearing is pressed on is shearing off and destroying the ring and pinions at the same time.
  2. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I'm pretty sure it was 89.
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Yep, 1989.
    Mike
  4. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Ill third that...
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I will 4th and finalize that. /forums/images/graemlins/grin.gif
  6. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Thanks guys. I found in the LMC catalog that 1988 was a questionable year...depended on the ratio.
