10 bolt rear disc?
Discussion in 'The Garage' started by stizkidz, Jun 21, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    I told a friend that I would ask the following question: Which manufacturers or vendors sell disc brake kits for rear 10 bolts? I already suggested that he run something beefier than a 10 bolt but he insisted that he already spent $1500 on the 5 lug wheels which fit these axles so, the 10 bolt must stay. So, who makes a rear 10 bolt disc brake kit?
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, these guys will bend over backwards to help ya!!!
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You could just get aftermarket brackets on Ebay and buy the other parts at Pep Girls or the Junk Yard...
  5. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    At the risk of getting myself in trouble.... I'll chime in here.
    First off, thanks for the good words guys! We really appreciate it!
    I part own Black Widow Performance. Yes we do sell a complete 10B disc kit, or you can buy it in stages. The reason for the price of the first kit is that the rotors are special machined to slide over your wheel studs, just like the design on the front of a disc brake car. You do have to remove your axle shafts to remove all the stock hardward, but you do not have to press your studs out of the shafts. It makes for a very easy swap. Most other kits that I have seen require you to press out yourt wheel studs and mount the rotor on the back side of the axle flange. Our design elminiates that. We are running this design on several trucks. I fact, I run it on my blazer 12B rear and I have had no issues. I installed it approx. 6 months ago and it still works perfect.
    And yes, we will do our best to help you out in any way possible! :cool1:
    Also, right now, we are offering free shipping through the end of the month. That works out to a bigger discount than if we were to offer the standard 10% off to CK5 members. :thumb:
  7. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Oh why not... I will throw in my .02 here... I run the BWP rear kit on my 1st gen and absolutely love it... but then again, I designed most of it, so I am probably a little bias.
    However, if you (anyone) are unsure about the BWP custom kit, you can also buy a WilWood kit through us as we are a WilWood distributor...
    -Ryan
  8. stizkidz
    Nov 11, 2004
    219
    Since this is going to be done to a 2wd truck, he needs 5 lug rotors. Does anyone sell just the brackets and spacers so he doesn't have to buy 6 lug rotors that he cannot use???
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Drop us an e-mail. We can help you out. The 6 lug rotors in the picture are for the 4WD application. The 2WD application is the same, only a 5 lug rotor.
