10 Bolt Rear Durability????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AK-5GUY, Nov 29, 2002.
  1. AK-5GUY
    AK-5GUY Registered Member
    Apr 24, 2002
    89
    Greensboro, North Carolina
    I just bought an 87 K-5 with the 28 spline 10 bolts front and rear. It is completley stock right now but I would like to get a lift and some bigger tires. How big can I go with the 10 bolt rear?? What will it hold up to during moderate four wheeling like mud pits and some minor rock crawling? Also, what gears should I get for those 10 bolts with the 700R4 transmission for those tires. Thanks alot. Harrison
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Save yourself the money and trouble and upgrade to 3/4 ton stuff from the beginning. You should be able to find a 4.11-geared 14 bolt rear and a matching 10B or D44 front for around 500 bucks.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Procrastinaion is like masturbation; it seems like a good idea at the time, but in the end you're really only f*cking yourself.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I ran 33s on my 2.73 10 bolts for not quite two months and the spiders in the back blew last week. They became shrapnel when I had 235s on it.
    If you drive like a girl you might get your rear ten bolt to last. I used to be an advocate of ten bolts. I'll still be one for the front but they aren't worth the powder (or horsepower) to blow them up in the back.
    It did hold up to 10 months or so of beating with 31x10.50s under it. 33s were too much for it.
    If you care to read the post I just made on ORC here it is:
    http://bbs.off-road.com/ubbthreads/showthreaded.php?Cat=&amp;Board=truck&amp;Number=957947&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=&amp;fpart=1
  5. dyeager535
    26,980
    I resent that remark! /forums/images/graemlins/tongue.gif
    Seriously though, he's right. You want to spin big tires at high RPM's, or just generally beat on your truck, don't spend money or bet your life on a 10 bolt. They just won't hold up.
    I spin my tires once in awhile, but I try and make sure I'm doing so where I have very little traction. (less load on the diff) Besides the fact I have a gov-lock, and don't feel like replacing everything if I destroy it. /forums/images/graemlins/smile.gif
  6. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I also have a '87 Blazer, 10bolts front and rear, 3.08 ratio with 33's. It has 170,000 miles on it. One of the previous owners used it as a plow truck. The rear diff is loose and sloppy, axle surface at bearing worn to the point where new seals won't hold the grease in, always weeping. I offroad this, even use it to pull a trailer loaded with firewood out of the woods during cutting season. The only reason it has survived is "I DRIVE IT LIKE A GIRL". /forums/images/graemlins/blush.gif There I said it /forums/images/graemlins/grin.gifI think the most important thing is to know your vehicles limitations. If you do, breakage will be kept to a minimum. I have spare front and rear axles and I also have the dreaded "Auto-Hubs" and spares for those too. Regular scheduled maintenance maintenance will keep you aware of problems also. I'm also going with 1 ton driveline next spring so I can drive like a man when the conditions require it. Bottom line, know your weak links and drive accordingly.
  7. RedBrute
    Sep 22, 2002
    346
    Oh and fill out your profile with as much info as possible. Most folks here like to see what you got so the responses are more accurate. Also, the "ProfileHunter" will get you if you don't. /forums/images/graemlins/smirk.gif
  8. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Wasnt it DesertDueler that was hill climbing on 35s and sheared off the pinion causing him to roll several times.
    He walked away and lived to tell about it. Someone posted..."10 bolts can kill". /forums/images/graemlins/rotfl.gif
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my 10 bolt blew, only because it was old and sloppy and i had big tires on it, 33x12.50's and im sure the way i drove it didnt help. stilll it really depends on who drove it and how your going to drive it, that will tell you how it will last. /forums/images/graemlins/thumb.gif. by the way i found a 12 bolt for free, that is the only reason i kept it 1\2 ton /forums/images/graemlins/grin.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I blew my 12 bolt backing out of a parking space...shrapnel right through the cover. I for one would not consider a 12 bolt to be any significant upgrade over a 10 bolt.
    Rene
  11. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Stock Gov-Locks give up like a swapmeet watch /forums/images/graemlins/1zhelp.gif Go with an aftermarket lmtd slip and call it good.
    Jim
  12. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    yea gov locs do suck, the 12 bolt is an open diff, i might put in a locker or limited slip some time down the road. I cant complain since i got it for free with a extra parts axle (front 10 bolt) so if i ever completely snap my front axle in half, as long as i dont ****up anything really bad i have a spair axle. /forums/images/graemlins/thumb.gif.
