10 bolt rear end ques.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wickedk5, May 5, 2000.
  1. wickedk5
    wickedk5 Registered Member
    May 3, 2000
    30
    Ca.
    i have a '90 blazer scottsdale with a 10 bolt rear and was wondering if anyone new what the final drive ratio is?
    thanks
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
  3. jsc383
    jsc383 Registered Member
    Apr 8, 2000
    22
    3.08 had to have been the most common for the stock, next most common was 2.70 or something like that a iduno
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    You could have 3.08, 3.42, or 3.73 gears from the factory. With the advent of the overdrive transmission (if it is an automatic) and fuel injected engines, it seems as if most of the late '80's to early '90's Blazers had either the 3.42's or 3.73's.
  5. Kiblsnbits
    Kiblsnbits Registered Member
    Feb 20, 2000
    92
    Cincinnati
    What would a 10-bolt from '83 have stock?
    Blazer: A hole in the air, surrounded by metal, into which one pours money
  6. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Well.......I would say you had about an equal chance of having 2.73, 3.08, 3.42, or 3.73 gears.
  7. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    I have 2.73's in my 89 K5. Whose idea were 2.73's? Pity me.
    As undesireable as this ratio is, don't rule it out. I'm running 32X11.50X15 BFG muds, and I just spent $1450 on a complete rear-end rebuild. Hope you don't have 2.73's my friend.
    10 BOLTS O' FUN
  8. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    I have `89 K5 Silverado with a 12 bolt rear axle 2.73 gear and 32x12.5/15 tires and this is not a good gear setup i`m driving 75 mph by 1450 rpm. i think 3.42 or 3.73 are the right ones for me.
    River
