10 bolt rear end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jayccb1, Feb 12, 2004.
  1. jayccb1
    jayccb1 Registered Member
    Feb 3, 2004
    12
    wisconsin
    I had someone tell me that an eaton 10 bolt rearend was stronger than the stock. I've never heard of the eaton. Does anybody have any info?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    When talking about an Eaton axle, most people are referring to the rear axle used in the back of 3/4 ton (?) and 1 ton GM trucks before 1973 (which, after that year, were replaced with the 14 bolt). If I recall correctly, the Eaton rears did in fact have 10 bolts holding the cover on. They are not as easy to find (or find parts for) as the 14 bolt...thus making them less desireable of a rear axle for a swap.
    P.S. Where are you located in Wisconsin?
  3. jayccb1
    Feb 3, 2004
    12
    wisconsin
    Racine, I believe they were saying the gute inside the 10 bolt were eaton. It was supposed to make the 10 bolt better.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Eaton also makes the Gov-locs that go inside 10 bolts. In the 70's and 80's they were weak. Considerably stronger now but hardly anyone will use them anyway.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i know that the '73 model year 1/2 ton and cars were still getting the good strong true clutch pack posi/limited slip G80 units
    also ther eis a rumor that the old h052 and h072 carriers will work in 14 bolt FF housings, i dont know how much truth there is to this still yet
