10 bolt rear on k5
Discussion in 'The Garage' started by blazindorito, Nov 29, 2003.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I went 4 bying this weekend in my 83 k5 2500. The blazer was doing great all morning. The last hill was 200 yards up about 150 yards up my differential broke. The tires came off had 2 get a tow truck, To get me out. I don't know why this happened. Does anyone have an idea and what should I go with next? I'd appreciate any help. Thanks in advance. I dont have a lot of money. What would be my best bet so this doesn't happen again. Paid an $800 dollar tow.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    First welcome to CK5 /forums/images/graemlins/thumb.gif
    Second your tires came off because the axle is a semifloating type meaning the tires and axles are held in by c-clips. If these or the axle break your tires fall off.
    As far as axle upgrades you can go with a 12 bolt (not much stronger) 14Bsemi floater (strong axle, but same thing can still happen) or the 14B full floater (strongest and cheapest) That is what the majority of people here run and are going to tell you to run. They can be found pretty cheap and are a easy swap just need a u-joint /forums/images/graemlins/thumb.gif Only downside is you have to run 8-lug wheels which means you should probably change your front axle to 8 lug so you don't have to carry two spares
    Ohh by the way please fill out your profile so we know where you are and what you have thanks
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Swap in a Corporate 14 bolt full floater and an 8-lug front axle. You will not break the 14BFF. $800 would have bought 2 axles and 4 8-lug rims. There is a ton of info about axle swaps on this site, just do a search for "axle swap" or "14BFF" and you will find more than you can read. /forums/images/graemlins/thumb.gif
    FYI, 10 bolts are notoriously weak, there have been many stories on CK5 about grenaded 10 bolts. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I went 4 bying this weekend in my 83 k5 2500. The tires came off had 2 get a tow truck, To get me out.
    83K5 2500? Do you mean 83K5 K-10? 2500 is the late model 3/4 ton number, just curious. /forums/images/graemlins/smile.gif
    Do you have any pics? I would find a 14BFF which is industructable basically or a 14BSF 6 lugger that you would probably never break.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    agreed..like the others said..swap in a 14 bolt full floater and forget about it! /forums/images/graemlins/thumb.gif
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Or at least carry spare shafts and go easier on the skinny pedal....
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sounds like shafts broke, and that you need a full floating axle for how you are running the rig
    2500 is gmc truck since way back in '60's or even before.
    2500 is also later chevy 3/4 ton also nowadays
  8. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i agree, 14ff is the way to go. and welcome to CK5!!
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Did the tow truck driver at least give ya a 'reach around'? Dinner first? /forums/images/graemlins/eek.gif
    Rene
  10. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    For the $800 dollars i wish he would've kissed me. HE just F***ed me. Thank you for your replies. I will swap the 10 bolt for the 14bolt ff. What kind of truck should I be looking for?
  11. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    I am not sure if it is a K5 or K10. The sign on the side of the blazer says K5 but I also think it is a K10. I'm not quite sure. Pictures I'll post the ones of the truck w/ broken axles.
  12. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    blazers are k5's trucks are k10's
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Find a 1973-1987 3/4 ton GM truck, 2wd or 4wd, it will be the same, also check for 1973-1991 3/4 ton subs, make sure it is a fullfloat design, there are some light duty 3/4 tons runnin around. A 14BFF will have a hub with 8 bolts for the axleshaft plus 8 studs for the wheel. There is not much of a difference in the axle itself other than gov-locks/open carrier, brake drum size, and shock location. A 3/4 ton will literally bolt on using 3/4 ton u-bolts and 3/4 ton plates. I snagged a set of axles (D44/14FF) off a parts truck 2 years ago for $200. It was the best mod I have ever made. Just watch for gear ratio, and if you want to add a locker downt the line get an open carrier cause a detriot drops in it.
    Good luck
