10 bolt rear pinion seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jacksprat1599, Jun 8, 2004.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I would appreaciate any input on how to install a new seal on my subarbans rear axle.any special tools or considerations
  2. bga
    bga Registered Member
    Jun 5, 2004
    27
    -- Remove the driveshaft yoke from the diff.
    -- Remove the old seal using a hiik/pick kit or whatever works best for you.
    -- Carefully get the new seal started, then using a socket (or something similar) of the same O.D. of the seal tap the seal into place.
    -- Replace the yoke and your done!
  3. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What about the crush sleeve? /forums/images/graemlins/rolleyes.gif
  5. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    the pinion is allready set, so put shims in instead of a new crush sleeve. Just measure the thickness of the sleeve and get some spacers at the parts store. Don't over torque the pinion nut.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put something like assembly goo on the spring so it doesnt come off when installing it.
    What about it? /forums/images/graemlins/dunno.gif Its already crushed, just put locktite on the nut.
    I suppose you shoud torque it down, but I just do it by feel. Dont make it too tight as you will kill the bearings, and dont make it too loos as you will kill the ring and pinion.
