10 bolt rearend
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lugnut, Oct 15, 2001.
  1. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    Could someone please tell me what year the 10 bolt rear started and are they alot weaker than the 12 bolts? Also what year was the 203 replaced?Is the replacment t-case better or worse?
    78 sub 454. Big as a tank and hard on my bank.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    10-bolt production shifted in 81. (My Jimmy with all her projects!
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    From my personal experience, the spider gears in the 10 bolt are weak. I grenaded mine a couple months back. A 12 bolt would be a good upgrade or just throw in a 14 Bolt FF and be done with it.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  4. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    If you are going to swap axles, go for the 14 bolt. It wouldn't be worth the swap to just go to a 12 bolt. If you just want bigger gears, I have a set of 3.73s with open carrier I would be willing to part with if you would be willing to contribute to Brian's "Clean Out The Garage" Fund!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  5. lugnut
    Aug 3, 2001
    268
    North Carolina
    Thanks for the replys and for the link.I knew the info was here. I just didnt know where to look. Im still learning about this internet stuff.Still learning to type to.
