10 bolt shaft break
Discussion in 'The Garage' started by Cricket, Nov 20, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Thought some of you 10 bolt axle guys might find this interesting.
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what size tires did that? good thing im buyin a 60 :D
  4. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I bought this axle off a 1980 3/4 ton stock truck so I could get the 8 lug hubs for my swap. This was the reason the PO sold it.
    Good demo of something that could happen on trail run. In order to get the inner shaft out past the knuckle I had to use a cut-off wheel on the joint ears.
    Fun-fun for me, my 1st up close encounter pulling a busted axle apart.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so that explains why nobosy will buy my 10b shafts :haha: :haha:
  6. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Ha, that's exactly why somebody should buy them for spares. :D
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    You mess with that lower ball joint at all? Where'd you break it??
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ur right they should, but nobody wants them :doah: and i know not everybody is goin to a 60
  9. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    You are gonna have a BLast getting the nut off that lower ball joint!!
  10. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Once I got the shafts out the nut was easy to reach. :D All I need now is a wider pickle fork to pop the knuckles off. My tie rod fork is too skinny. I didn't mess with the ball joint and the break was at the u-joint ears - more of a shear.
    Mike PM me your addy again and I'll send you the spicer lockouts.
  11. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Ummmmmm should I go check those two boxes you just sent me? lol j/k!!!
  12. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Don't worry Shane. The shafts you got didn't come out of this axle.
  13. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Why do you need to pull the knuckle if all your doing is converting another axle to 8 lug? Its the same knuckle.... :confused:
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Experience.
    The more I know about taking it apart and putting it back together the better off I'll be if something breaks.
  15. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    My son did the same thing yesterday on the drivers side of his lockrite'd 10 bolt. Already had spares at the house.
  16. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I think that break might, just maybe, have something to do with the original 1980's super dry, really rusty, hasn't seen grease in 10 years, u-joint. That is just a possibility.
    PS D60's break too :doah:
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dont tell me 60s break....blah blah blah i cant hear you blah blah
