10 Bolt shafts and other stuff
Discussion in 'Suspension | Axle' started by mudhound72, Dec 9, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    I have a pile of 10 bolt shafts frount and rear $20 each
    Gears and carrers $20/set
  2. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Have any 3.08 and up carriers? I just found that my K5 came with 2.73's.Got any ideas?
  3. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I think I have one with 3.5??? and one that had 3.73 I will get out to the shop in the next day or two and let you know :D
  4. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Was wondering if the 3.73 carrier would fit a 94 Yukon 10 bolt? Also does it have all the spiders and guts? Thanks.
  5. 89K5guy
    Jul 11, 2005
    174
    Ohio
    Thanx for looking.If you want to pm me that is fine too.
  6. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    do you only have the two carriers? I am looking for some cheap 4:56's (preferd) but would take 4:11's
  7. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I know for sure that I dont have any for a 4.10 and up
  8. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    have a 30 spline pass side shaft?
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The carrier break on 10 bolts is 2.56's not 2.73's I believe.
    A 94 Yukon 10 bolt would have a 30 spline carrier so make sure you buy parts accordingly.
    Harley
  10. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    Have a friend looking for a ring and pinion for a 10 bolt 3:42 gear Thats What igot when doing the math. The ring gear is 41 teeth and the pinion had 12 teeth if that helps. Let me know what you got thats. Would also need the carrier/spiders they are shot as well. Shipping would be to 28304 and might take an outer shaft or two as well for the front if you got them. Thanks.
  11. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I know that I dont have any gears that are 3.42, I do have a few sets of shafts
  12. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    You got any 30 spl. front 10 bolt shafts. Need the long side, both inner and outer.
  13. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I think that I have 1 just as long as it did not grow legs like the rest, 20+s&h
  14. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    If you can find it, what would you want for it.
