10 bolt swapping
Discussion in 'The Garage' started by 84k5, Jan 27, 2004.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I am thinking of buying a pair of 10 bolts and swapping them in place of mine in order to gain some gearing (4.56 v. 3.73).
    However, I just got the brakes done at a shop, so I want to pull them off my current 10 bolts and put them on the 4.56 units. The front looks like cake...what about the rear?
    Also...how much do these weigh? I need to get them in/out of the truck and I don't have a hoist or anything.
    TIA
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    they don't weigh much. not after moving around a d60.
    you can do it with another person.
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I can't help you with the brakes, but I don't think it'll be too hard. As far as moving them, getting them in will be a challenge, but I unloaded a dana 60 and 14FF by myself out of the back of my truck about a week ago. It wasn't very easy, but I got them out. Heavy as all get out!
    Kris
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    drums will swap right over without loosening a line or breaking them down.... same with the front, leave the brakes alone swap hubs rotors etc over!
    Did the same with my rear brakes when I swapped to my 12 bolt rear, same brakes /forums/images/graemlins/waytogo.gif
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    u can swap ur new brakes right over, same axle, just swap ur pads/roters/drums, and calipers if there better or new..
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Better yet, just unbolt the entire backing plate with everything attached and then re-bolt it to the new axle. The only thing you would then have to do is remove the axleshafts to do that.
    Either way, it should take about 45 minutes to do the rear and 30-45 to do the front.
    John
  7. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Kris
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    note to self: dont mess with Kris /forums/images/graemlins/cool.gif
  8. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Little of topic about the swapping, but related to 10 bolts...
    I have 10 bolts too, and since i dont have enough money to buy and rebuild d60 and 14ff do you guys think that these little half ton axles will handle 35s? I also just put in a pretty beefed up small block so what do u guys think?
