10 bolt tie rod on Dana 44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RedDwarf, Sep 6, 2001.
  1. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Anybody running this? looks like a cheap way to gain an inch of clearance for the old bendy-stick. I am replacing mine(the ends were worn out) and I had the 10 bolt one lying around. It is going to fit, but I first have to unbolt the spring on one side and jack the truck up so the end can clear the knuckle.
    Just thought I would share the tip, don't know if it's been done...
    Lift It, Lock It, LIVE IT!!!
  2. Grim-Reaper
    7,385
    Atlanta
    why not unscrew the adjustment sleave and bolt it in the arms then rethread it when it's on. Seems a little easier than taking a spring loose.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
