10 bolt to 14 bolt and front axle
Discussion in 'The Garage' started by Tshane, Dec 3, 2002.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    Okay i have 2 questions guys hopefully someone can help!!
    I'm about ready to do somethign to my axle and everyone i have talked to says a 10 bolt wont hold up to a 383 power. Meaning i'm going to have to go a 14 bolt what kind of modifcation and work will this take to make this work?? What parts will i have to be change or replaced??
    My other question is what should i do about the front 10 bolt axle??? /forums/images/graemlins/1zhelp.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    A 14bolt from a 73-80 2wd or 4wd 3/4ton pickup will bolt right in. You will need a conversion ujoint since your driveshaft is 1310 and the axle is 1350. NAPA sells these.
    What to do about the 10 bolt - not much can be done. You can buy alloy shafts. You can buy CTM ujoints. You can either tyr to take it easy and not kill the axle or upgrade to a Dana 60.
    -- Mike
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    now your talkin' /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I bought a set of 3/4 ton axles from a wrecked 3/4 ton pick-up. [​IMG] The rear is a 14 Bolt FF and the front is a Dana 44. They are 8 lug axles, so I'm going to have to buy rims. I went with the 3/4 ton becouse I coundn't find a Dana 60 for under $1,000.00 and I got both these axles with matching gears for $250.00 . Granted, I didn't gain anything in the front, but I don't have to pay for new gears, or for the 8 lug outers now. Befor you go swapping axles, you need to decide on what size tires you're going to run, and see if you can find axles with gears in them that won't be to high that they kill you're transmission !!!!!!!!!
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    348 is the napa part # i used for the convertion!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    You going with a 14FF or 14SF?
