10 bolt to 14 bolt ff conversion question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bad_bo_ti, Jun 10, 2000.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    Does the drive shaft need modified(shorten/lengthen) by any chance when swapping in the 14 bolt? or are the 10 and 14 the same distance from center of housing to the yoke?
  2. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Your Drive Shaft is good to go just need a U-Joint 1310 to 1350 Napa #447
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 14-bolt yoke is closer to the front of the truck than a 10-bolt one is. But it compensates nicely for the difference a 4-6 inch lift makes in the distance from the t-case to the axle yoke. [​IMG]
    http://ThunderTruck.ColoradoK5.com
