10 bolt to 14 bolt questions****1310>1350 u-joints
Discussion in 'The Garage' started by mostwanted, Aug 24, 2006.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I was reading the ck5 tech article on the swap. Does anyone have the part number for that u-joint that he refernces 1310/1350 combination? Also, what is the best method to deal with e-brake cables?
  2. Topless74
    Topless74 Newbie
    Jan 10, 2006
    Las Vegas, NV
    My ebrake cables hooked right up. I don't remember the pn of the u-joint though. Go to either NAPA or CArquest and they out to be able to look it up for you.
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    A 10 bolt shoulr have a gm s44 joint. The napa p/n is 447 or 477, I cant remember.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    and they're NOT cheap either :doah:
  5. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I see this question all the time. Idon't know what size my U joints are. I've just ordered them by application. I went from a 87 10 bolt in a half ton to a
    ff 14 bolt srw unknown year and I didn't need a conversion joint. Is this only certain years?
  6. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    B_to_C found out the hard way that you can get an S44 joint to work in a 14bolt yoke. You think it's in there okay, but upon close inspection you'll realize it's a little loose.
    mostwanted, you need the following:
    Napa: (S44)10b -(1350)14b = #447
    or
    Carquest: S44 to 1350 (3/4/1 ton) 2-1153
    And yes they're pricey!
  7. farshot1
    farshot1 Surrender the Booty
    Mar 17, 2006
    37
    South Carolina
    I just did mine this week, after 5 trips to Napa I got the right part number HERE, It is Napa #250-0447
  8. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    alrighty, thanks. I did see a post in the 73-87 forum, but the info is contradicting. At least I am down to 2 different part numbers to try. Also, what will I need to do to the front driveshaft to get a dana 44 or dana 60 in there?
  9. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Nothing with the u-joint.
  10. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Thanks for the info. I'm hitting the trail in the morning and no parts stores anywhere near where I am or where I'm going. I hate finding out somethings wrong with no time to fix. Guess I'll pick up that Napa 447 Monday.
    Wish me luck.
