10 bolt to 60 crossover steering
Discussion in 'The Garage' started by shaun, Oct 13, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I just swapped to crossover on my 10 bolt a week agao and now I have a 60. Will the tierod and draglink swap over. I know I need a new steering arm and install kit. Does the 60 passenger knuckle have to milled drilled and tapped? Will the spring perches align. My jimmy is a 90 and so is the 60. Does this make a difference? What should I know when swapping a 3/4 ton 10 bolt out for a dana 60? /forums/images/graemlins/histerical.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    60 will swap right in, need u bolts and springplates for the 60 of course. Spring perches are the same. Passenger side kinpin is held on with a cap, steering arm replaces that cap. Means no milling, drilling, or tapping. Woohoo. As for your crossover, I'm pretty certain it should just swap over. Of course will require TRE end adjustment. Heck your brakelines will swap right over the 60 even /forums/images/graemlins/thumb.gif oh and you could search and find all this /forums/images/graemlins/wink.gif
  3. shaun
    Apr 22, 2003
    745
    thanks sled dog i appreciate all the info
