10 bolt to d44 u-joint?
Discussion in 'The Garage' started by low 84, Jun 25, 2005.
  1. low 84
    low 84 Registered Member
    Jan 4, 2005
    45
    college station, tx
    when going from a 1/2 ton front 10 bolt to a 3/4 ton front d44 what u-joint do i need?
    TIA
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    real hard to do. just bolt it on. good luck. i did this to my old truck worked good.:D
  3. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    don't think it could be a whole lot more simple... remove the old, replace with the new with the same bolts and crap and you're good to go!
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    if its a mid 80's 10 bolt with the internal snap rings on the u-joint, you need a conversion joint for the drive line that converts it to 1310 style u-joint so it will bolt up to the dana 44.
  5. low 84
    Jan 4, 2005
    45
    college station, tx
    lol, thanks for the help guys. i'm sure i sound like an idiot now, but my front shaft wasn't installed with the 10 bolt and there isn't a u-joint in it right now, so i couldn't check to see if they were the same.
