10 bolt to dana 44 ? any tips?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by random, Jun 12, 2002.
  1. random
    random Registered Member
    Jun 12, 2002
    13
    maine
    in process of changindg 10 bolt axles to 12 bolt and dana 44 .any probs i might run into?
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    my question is why swap in a 44?..the 10 bolt front is based on the same design as the 44 and not all that much stronger /forums/images/icons/confused.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    From the looks of what he's swapping, probably to get a matching pair. /forums/images/icons/grin.gif
  4. random
    Jun 12, 2002
    13
    maine
    yup lol exact reason for the swap?? im cheap and housings were free!!!! looks pretty straight forward will try next week.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Not an issue. The 44 should bolt directly in place of the 10 bolt. Only issue may be brake lines. You may have to buy new flexible line (from frame to caliper) because the banjo bolts on the calipers are different.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    brake lines are fine, just use the calipers off the ten bolt.
    and remember this so when youneed to buy parts you know.
    grant
  7. Leadfoot
    Nov 28, 2000
    3,112
    Good point! I forgot the calipers are interchangeable. /forums/images/icons/blush.gif /forums/images/icons/blush.gif
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I changed my 10 front to D44 for gears and 8 lug and I just drilled the brake lines bigger for the D44 calipers
