10 bolt to this, what do I need?
Discussion in 'The Garage' started by cochino12, Oct 8, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I am swapping my 10 bolt for this 14 bolt, now what do I need for the swap? Will my 4" lift blocks and ubolts work? Am I going to need a different u-joint? if so does anyone have a part #. Thanks for the help.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You need different u-bolts , blocks will work . The u-joint was posted in the members section in the part number post /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Wow that is a great thread. Thanks never noticed it before. /forums/images/graemlins/thumb.gif
  4. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Stupid question /forums/images/graemlins/confused.gif Do I need to do anything to make these brakes work?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    2-1153 for a neapco or I can get you a spicer joint /forums/images/graemlins/smile.gif
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Whats it going into? Does it have the u bolts pointing up or down? If there down you can just get u bolt plates off a truck that came with a 14b.
  7. cochino12
    Dec 23, 2003
    563
    Parker, Co
    I actually just got some new ubolts and plates from ORD.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stupid question Do I need to do anything to make these brakes work?
    Most GM rear brakes will bolt on to your block/brake hose in the rear if you are using the axle complete so that won't be an issue , and I am sure a semi floater will be close enough to work with your stock braking bias . I do not know what to do about E-Brake cables , but maybe yours can be adapted . I am sure someone will chime in on the E-Brake issue /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
