10 bolt upper ball joint adjust. sleeve--HELP!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Silv4x4, Dec 13, 2002.
  1. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    I'm in the process of a front end overhaul and got a question. Is the adjsutment sleeve on the upper ball joint supposed to be a single piece? I assume that it is but both of mine came out in two equal halves. If it should be a one peice I will obviously need to replace it but is this a dealer only item or might I be able to pick it up at a local parts house tomorrow?
  2. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    It is supposed to be only one piece. It should have four slots on top and you will need a special four prong socket and torque wrench to adjust it properly. Follow your chiltons book EXACTLY on the procedure for torquing the ball joints and sleeve. I believe is is 30 ft lbs on the sleeve, but check you manual. Every ball joint I have ever purchased had the sleeve included. Be sure they did not give you two lowers, I have had this happen.
  3. 79Silv4x4
    Aug 14, 2002
    50
    Lawton, OK
    Thanks 74Chev!! I never thought to consider that the new ball joint might come with a new sleeve. I hadn't been to the parts store yet so I was worried that I was going to be SOL on the sleeve. I don't have a Ciltons book but I do have a '79 GM manual so hopefully I will be okay.
  4. 74Chev
    Sep 19, 2002
    102
    Oregon
    Yeah, the GM manual will work fine. One word of advice from a lot of experience, get the most expensive ball joints you can. They are worth it, so you are not tearing the front end apart all the time. I like the napa fleet duty joints. They outlast the cheapies by four times easy, and like I said earlier follow the torque recommendations, things will last longer and work better.
  5. 79Silv4x4
    Aug 14, 2002
    50
    Lawton, OK
    What about Moog? I want to buy good stuff but NAPA is twice the price of Moog and I have heard good things about Moog....
