10 Bolt vs D44
Discussion in 'The Garage' started by drofdar, Nov 30, 2005.
10 Bolt vs Dana 44 Front Axle
  1. 10 Bolt
    137 vote(s)
    61.2%
  2. Dana 44
    87 vote(s)
    38.8%
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    My 1980 CK20 has the original 10 bolt front end and I have not installed a locker yet. I also have a Dana 44 front axle from a 73 Burb. Since I've been told that these two axles are similar in strength, I thought I'd put it out there for opinion.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Pulling the axle out is extra work . Besides , 10 bolts came in more model years , so shafts are in abundance .
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Given those 2 choices I voted 10 bolt as they are quite abundant in the junkyards and parts are cheaper than anything with Dana stamped on it. :D
    Ira
  4. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    10blt, cause it's what i am running up front :D
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    10bolt for the reasons listed already; and if you think about it, the D44 is an older axle so it has more age and probably more wear on it too.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    10 BOLT. already there. Just get an extra set of shafts.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    that d44 of urs will have flat knuckles, put them on ur 10b and do crossover-steering ;)
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    10 bolts are easier to set up the gears....you don't need a press or special bearings to do it....and they are in junkyards everywhere. Course they aren't as good as that awesome 12 bolt front end.... :haha:
  9. sandawgk5
    Oct 28, 2003
    6,881
    So who is votin for the 44 and dont care to enlighten us as to why? :rolleyes:
    Ira
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    thread on pirate showed side-by-side comparisons of the ring, pinion and various other parts on both the D44 and 10b. Without exception the 10b part was the exact same size, or larger. Stick with the 10b.
    j
  11. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    Maybe I'm just looking in the wrong catalogues but I find that aftermarket support for the Dana 44 is much stronger since it was offered in more then just chevys for front ends and were used as rear ends as well. I have a Dana 44 but it's just cause I bought a matched set of 3/4 ton axles. As far as strength and ease of maintnence/spare parts, I would say the 10 bolt, for options though, go with a 44. Almost all the differential made you can get for the 44, and when new parts hit the market, often it's for the 44.
    Myself, I plan on going to a D60 front eventually so I'm not putting a dime into my Dana 44. But if I had a half ton with a 44 in it that I wasn't planning on putting '35s or bigger on.....
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I voted D44 b/c that's what I have, but also with what wantedadodge says about the aftermarket support. I've seen a lot more options for the D44. :D
    Rick
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    10B, easier to get cheep shafts for and 2.73-5.13 use the same carier.
    D44, flat top knuckles and a better stock cover.
  14. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    Will D44 flat top knuckles install directly onto the 10B, for crossover?
  15. sandawgk5
    Oct 28, 2003
    6,881
    Yes they will.
    Ira
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Oh , and before I forget , another reason for 10 bolt over d44 .
    I absolutely hate having to pull the carrier , pull the ring gear , and drive out a damn roll pin to pull the crosshaft out to install a lockright .
    Did that once for the last time :D
  17. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Dont know if this is true or not, but heard that Dana 44's have weaker spider gears than the 10b's. Not sure though, just something that I heard.
  18. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The earlier D44 run smaller U-joints, and some run the external hubs.
    Rene
  19. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I run a welded 10 bolt with 39.5 IROKs.
    No breaky...yet.
  20. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    I have the same question
    I have the same question regarding the 10bolt vs. Dana 44. I have a useable 10 bolt front and a flat top D44 front, and both have 3.73 gears. I also have a spare 10 bolt and a spare D44 that are complete. I plan on doing a lockright in the front of my truck, now the question is which axle do I use for my build? Kevin
